Her zaman sadece LPG kullanabilir miyim?
25 Ocak 2021
Istanbul
I just bought the car, filled the gas tank and I plan to use only the LPG tank because it's cheaper and there is no reason to use gas. Is it healthy for this car? Is it safe to do this?
Sıralı sistemse LPG kiti buna 3 kere yapmana müsade eder sadece. Oda kötü günlerde benzin pompan arızalanırsa diye. 3 kereden den fazla asla yapamazsın.
Yes, you can use only on LPG. At first, your car uses gasoline until warm up, then it starts to use LPG. It is not harmful to your car in normal use but after 4500rpm we recommend to drive it with gasoline for valves' health. The clearence between valves are changing on LPG use after 30-40k kms so you've got to make the clearance for valves at the service. That's all.
@siviq sadece lpg ile kullanabilir miyim diye sormuş dostum. Daha ucuz diye onu kullanmak istiyor da. Arabaya bir zararı var mı diye merak etmiş.
[USER = 23717] @siviq [/ USER] asked if I can use it with lpg only. He also wants to use it because it is cheaper. He wondered if there was any damage to the car.
Thanks for the info. Is the clearance for valves under the 6 year warranty? Do I void the warranty by driving on LPG only?
The car you have just bought has a lpg system that mounted in factory. Therefore, it has a 6 year warranty too like any other new Honda cars. So, it does not voids the warranty with LPG usage. But make you sure to visit the authorized service shop in every 10k kms for maintanance. Otherwise the car gets out of warranty.
To be clear on the last point, I have to do a periodic maintenance every 10k km to make sure my warranty continues?
Also, what else do I need to do to make sure my warranty continues?
Thanks in advance
Thanks in advance
You should go to the authorized service for periodic maintenance on every 10k km or every year which comes first...
Thanks in advance
Basically, just the periodic maintanance is enough but you should read the user manual for other conditions.
