Multivizyon 1.F196.47 nin servis girişi
30 Nis 2019
Arkadaşlar bende yeni Honda civic vtec eco exe. 'den alarak aranıza katıldım.
Sorum ekrandan google'a girememek, HDMI'dan telefon görüntüsünü ekrana yansıtamamak.
bunun servis menü girişi nasıl, yabancı forumlarda servis menüsüne girerek google ve hdmı 'ı aktif hala getirildiği yazılı.
android auto yu kurmayı başardım. ama browser a giremiyorum.
genelde aşağıdaki gibi anlatmışlar ama sanırım bizim cihazlarda bu servis girişi çalışmıyor.
Bilen varsa yardımcı olursanız memnun olurum.
Saygıar
alierman
Enable Web Browser
Step A1: Hold Brightness button + Power Button + Menu Button all at once.
Step A2: Select Detail Information & Setting
Step A3: Press & Hold Menu button for several seconds until more options appear.
Step A4: Use the touchscreen to scroll down and select "Special Function Setting"
Step A5: Select "Cancel Android Restriction"
Step A6: Back all the way out of the menu using the top right back button.
You should now see the browser on the apps screen of the head-unit.
HDMI hack:
1) Hold the power button, the eject button and the home
button at the same time for about 3 seconds until you see a menu with two options which are self-diagnosis
mode and detail information and setting. Hit the detail information and setting. 2) Now hit the menu button
on the left for about 5 seconds until you see the screen that says fan setting, volume setting, vehicle
model information and etc. 3) Hit the vehicle model information. 4) hit the DD VSP error button and turn
it off. 5) hit the return button until you reach your home screen.
Now it is disabled, so go to your HDMI setting from the home screen then set your Android to cast and you
will be able to mirror your phone while driving. You can mirror your apps like Waze, watch videos during
road trips for your passengers (not recommended, but it's possible lol) and etc as you can see in my video!
Be careful and watch your surroundings!!!
Kategori
30 Nis 2019
Yukarıda ingilizce mesajda yazdığı gibi en üstteki gece-gündüz parlaklık düğmesi+güç düğmesi+menü ye aynı anda (3 üne birden) basarsanız servis menüsü geliyor. Daha sonra da menüde basılı tutunca tüm servisler açılıyor.
Yanlız bir sorun olursa tüm sorumluluğun tarafınızda olduğunu iletirim.
ben bunu denedim yinede browser ve hdmi'da bir şey yapamadım :( servis yolu gözüktü...
saygılar
alierman
